Hello Guest it is November 13, 2026, 11:27:40 AM
Author Topic: auto calculator decimal point not working  (Read 14431 times)
Offline tantan
  •  130 130
« on: October 12, 2012, 12:45:40 PM »
hi,
i use the auto calculator tool with a toch screen to enter values in the dro's. but the decimal point is not working.
tantan
Re: auto calculator decimal point not working
« Reply #1 on: October 12, 2012, 12:48:20 PM »
When using the calculator, always enter a "0"  (or some digit) before the decimal point.
Like this ....      0.4375
Russ
Offline tantan
  •  130 130
« Reply #2 on: October 12, 2012, 12:58:52 PM »
hi,
tnx for your reply. i always do that but even 12.56 dus not work. the decimal point is not working at all.
tantan
« Reply #3 on: October 12, 2012, 01:06:23 PM »
Might be associated with your touch screen set-up.
Wish I could help there but have no experience with them.
Russ
Offline tantan
  •  130 130
« Reply #4 on: October 12, 2012, 01:13:52 PM »
hi russ,
it has nothing to do with touchscreen drivers. if you would be so kind just select auto calculator in the operator menu. now you can fill in a value in an dro with your mouse. if you try for example 34.89 you will find that 34. will work but the 89 you cannot fill in.
tnx
tantan
« Reply #5 on: October 12, 2012, 01:19:52 PM »
I did try it before first posting and it works fine here.
Are you using the standard Mach screen ?
If not, the dro might not be set to accept decimal entries.  (%+.2f)
Offline tantan
  •  130 130
« Reply #6 on: October 12, 2012, 01:29:17 PM »
hi,
i solved it. it has to do with country settings in windows. i configured dutch (netherlands). after i configured English (US) it works!!
thanks!
tantan
« Reply #7 on: October 12, 2012, 01:36:19 PM »
Bravo !
I'll try to remember this one for future reference.
Thank YOU !
Russ
« Reply #8 on: October 12, 2012, 03:23:15 PM »
Yes, there was a French  guy had the same issue, thought at first it may be because he was using a laptop but ended up it was the language option he had set. He set the keyboard to UK and it worked fine.
