Hello
Guest
it is
November 13, 2026, 09:44:25 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
feddrate
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: feddrate (Read 22601 times)
Carnoustie, Scotland
Re: feddrate
Reply #10 on:
October 03, 2012, 12:23:02 PM »
You would normally have the ramp feedrate the same as normal cutting feedrate as it is really only plunge cuts where you need to have a reduced feedrate.
Is BOBCAD using your plunge feedrate for your ramp?
Logged
PCH
80
Re: feddrate
Reply #11 on:
October 03, 2012, 02:12:26 PM »
I am doing a plunge feedrate and then the cutting feedrate.
The parameters are on the same window so I chose a plunge feed
then the cutting feedrate. But the program runs the plunge feedrate
thru the code until it's last pass on a ramp cut.
Logged
Re: feddrate
Reply #12 on:
October 03, 2012, 02:27:32 PM »
Ok I see now, well seems like a BobCAD issue, maybe just a case of getting the post processor sorted out?
Logged
PCH
80
Re: feddrate
Reply #13 on:
October 03, 2012, 02:29:29 PM »
I suppose.
Logged
Re: feddrate
Reply #14 on:
October 03, 2012, 02:41:12 PM »
There is a guy from BobCAD posting on the forum quite a bit, ask in his thread and he may change it for you.
Here it is
http://www.machsupport.com/forum/index.php/topic,21342.msg156567.html#new
Logged
Print
Pages:
1
2
Go Up
« previous
next »
