Hello Guest it is October 04, 2026, 04:46:23 PM
Author Topic: feddrate  (Read 21913 times)
Re: feddrate
« Reply #10 on: October 03, 2012, 12:23:02 PM »
You would normally have the ramp feedrate the same as normal cutting feedrate as it is really only plunge cuts where you need to have a reduced feedrate.
Is BOBCAD using your plunge feedrate for your ramp?
Offline PCH
  •  80 80
Re: feddrate
« Reply #11 on: October 03, 2012, 02:12:26 PM »
I am doing a plunge feedrate and then the cutting feedrate.
The parameters are on the same window so I chose a plunge feed
then the cutting feedrate.  But the program runs the plunge feedrate
thru the code until it's last pass on a ramp cut.
Re: feddrate
« Reply #12 on: October 03, 2012, 02:27:32 PM »
Ok I see now, well seems like a BobCAD issue, maybe just a case of getting the post processor sorted out?
Offline PCH
  •  80 80
Re: feddrate
« Reply #13 on: October 03, 2012, 02:29:29 PM »
I suppose.
Re: feddrate
« Reply #14 on: October 03, 2012, 02:41:12 PM »
There is a guy from BobCAD posting on the forum quite a bit, ask in his thread and he may change it for you.
Here it is
http://www.machsupport.com/forum/index.php/topic,21342.msg156567.html#new
