Hello Guest it is November 21, 2026, 03:48:28 PM
Author Topic: WORK/ TOOL OFFSETS  (Read 8159 times)
WORK/ TOOL OFFSETS
« on: September 24, 2012, 05:40:11 PM »
HOW DO I SAVE THEM?
Re: WORK/ TOOL OFFSETS
« Reply #1 on: September 24, 2012, 06:00:57 PM »
When in the offsets table click the save button.  Save settings, also in general config there are DRO settings  ( lower right of the screen) and you can select if you wnat to be prompted to save the offsets ( doing this from memory so look at the manual ).
Some gcodes will cancell out the offsets and same goes for a initialization  macro, if using one, on startup.
