Hello Guest it is November 13, 2026, 05:04:25 PM
Author Topic: pulse rating  (Read 24945 times)
Offline mikee
  •  100 100
pulse rating
« on: September 14, 2012, 06:59:38 PM »
Back to ground zero
My pc got a virus I ended up having to erase the hard drive an reload my backup disc.
my back up disc were made when i got pc but i hadnt backed up mach 3.
I had to down load microsoft  service pack  1, 2 and 3 .
I down loaded mach 3 lic but when I am trying to config I cannot get any motor movement.
I went to check driver test it show 0 pulse rating ?   Is this the reason i cannot get any motor movment.
Mikee
Re: pulse rating
« Reply #1 on: September 14, 2012, 07:10:42 PM »
Mikee,
Did you run Driver Test?
John Champlain
www.picengrave.com
Offline mikee
  •  100 100
Re: pulse rating
« Reply #2 on: September 14, 2012, 07:33:29 PM »
yes
it said 0 pulse rating .
Mikee
Re: pulse rating
« Reply #3 on: September 14, 2012, 08:34:14 PM »
Sorry, overlooked that in your first post.
Was Mach3 running when you ran driver test?  If so, try again to run driver test with Mach 3 shut down.
John
Offline mikee
  •  100 100
Re: pulse rating
« Reply #4 on: September 14, 2012, 08:53:59 PM »
driver test with out mach 3 ..............   0 pulse.
with mach 3 running,  drive test  (this time it couldnt locate missing vectors.)
ran one more driver test with mach3 running  says  (system  under mach 3 control 0% pulse)
mikee
Re: pulse rating
« Reply #5 on: September 15, 2012, 05:31:41 AM »
Have you defined the port address?
Offline mikee
  •  100 100
Re: pulse rating
« Reply #6 on: September 15, 2012, 09:46:15 AM »
Hi rich
Yes  port 1     port is enabled    0x378      25000hz
mikee
Re: pulse rating
« Reply #7 on: September 15, 2012, 12:21:38 PM »
Is there a time in Int and a Frequency showing on the Diagnostics page?
Offline mikee
  •  100 100
Re: pulse rating
« Reply #8 on: September 15, 2012, 04:03:15 PM »
Diagnostics page
time scale + 1.000
time in int +0.0
blend speed 0.0
cpu speed 2690.0000
pulse frequency   0
Mikee
Re: pulse rating
« Reply #9 on: September 15, 2012, 04:10:22 PM »
Ok the driver is not installed or not installed correctly.
First thing to try is re-download Mach from the downloads page and install it again over the top of itself.
Have a look in device manager and see if the pulsing engine (driver) is there.
If that doesnt help then maybe try the specialdriver.bat that you will  find in the Mach folder.
