Mach Discussion => General Mach Discussion => Topic started by: mikee on September 14, 2012, 07:59:38 PM
Title: pulse rating
Post by: mikee on September 14, 2012, 07:59:38 PM
Back to ground zero
My pc got a virus I ended up having to erase the hard drive an reload my backup disc.
my back up disc were made when i got pc but i hadnt backed up mach 3.
I had to down load microsoft  service pack  1, 2 and 3 .
I down loaded mach 3 lic but when I am trying to config I cannot get any motor movement.
I went to check driver test it show 0 pulse rating ?   Is this the reason i cannot get any motor movment.
Mikee
Title: Re: pulse rating
Post by: Picengraver on September 14, 2012, 08:10:42 PM
Mikee,
Did you run Driver Test?
John Champlain
www.picengrave.com
Post by: mikee on September 14, 2012, 08:33:29 PM
yes
it said 0 pulse rating .
Mikee
Post by: Picengraver on September 14, 2012, 09:34:14 PM
Sorry, overlooked that in your first post.
Was Mach3 running when you ran driver test?  If so, try again to run driver test with Mach 3 shut down.
John
Post by: mikee on September 14, 2012, 09:53:59 PM
driver test with out mach 3 ..............   0 pulse.
with mach 3 running,  drive test  (this time it couldnt locate missing vectors.)
ran one more driver test with mach3 running  says  (system  under mach 3 control 0% pulse)
mikee
Post by: RICH on September 15, 2012, 06:31:41 AM
Have you defined the port address?
Post by: mikee on September 15, 2012, 10:46:15 AM
Hi rich
Yes  port 1     port is enabled    0x378      25000hz
mikee
Post by: Hood on September 15, 2012, 01:21:38 PM
Is there a time in Int and a Frequency showing on the Diagnostics page?
Post by: mikee on September 15, 2012, 05:03:15 PM
Diagnostics page
time scale + 1.000
time in int +0.0
blend speed 0.0
cpu speed 2690.0000
pulse frequency   0
Mikee
Post by: Hood on September 15, 2012, 05:10:22 PM
Ok the driver is not installed or not installed correctly.
First thing to try is re-download Mach from the downloads page and install it again over the top of itself.
Have a look in device manager and see if the pulsing engine (driver) is there.
If that doesnt help then maybe try the specialdriver.bat that you will  find in the Mach folder.
Post by: mikee on September 15, 2012, 05:38:53 PM
Have a look in device manager and see if the pulsing engine (driver) is there.  <<<<<<<   it is not there.
Post by: mikee on September 15, 2012, 06:05:12 PM
i was wrong i do have pulsing engine drive sorry i didnt see it.
Mike
Post by: mikee on September 15, 2012, 07:25:23 PM
up date I think I have more problems with my pc   now i dont pulsing engine drive .
Mike
Post by: mikee on September 16, 2012, 02:33:00 AM
up date I un istalled and then reinstalled mach3
 I am pulsing to fast is what driver test is saying now.
driver test said this one time before but I hate to say I have too much pulse and then say I have 0 pulse .  but that is what happened last time.
  dianostic screen in mach 3  Time in int +8.7
I do not have motor controll
Mikee
Post by: Hood on September 16, 2012, 04:15:41 AM
What does the Frequency say?
What Kernel are you using?
Can you try rolling back to SP2 in XP as I have seen people having issues with SP3.
Post by: mikee on September 16, 2012, 05:55:28 AM
What does the Frequency say?  >>>>>>>>>>>>>>>>>>>>>>>>> 23224
What Kernel are you using?  >>>>>>>>>>>>>>>>>>>>>>>>>>>   25000hz
 Ok i will try to switch  back to sp2  I also read where others have had problems with this.
Looks like windows service pack 3 there is some kind of issue I cannot uninstall it , the box that says click here to remove is not there ?
 But it is listed ?
thank you
Mikee
Post by: Hood on September 16, 2012, 06:54:57 AM
Ok thats relarively close on the frequency so not sure why the driver test is so bad.
Maybe doing a system restore to a point before you insatlled SP3?
Post by: mikee on September 16, 2012, 01:00:21 PM
___________________________________________________________________________________________________________________
I will do a systems restore .
Mikee
