Hello Guest it is October 21, 2026, 03:43:20 PM
Author Topic: Unknow g code help  (Read 13315 times)
Unknow g code help
« on: August 21, 2012, 05:22:31 PM »
Hey this is Todd-new user and new CNC user.
I have loaded a file on Mach 3 that is a part that someone is running for me now-he ran some yesterday,  His system is Enroute 4,
He gave me a copy that I was able to load in Mach and could see the gcodes, but then it gave me a status saying "unknown g code Line 3"  This Line 3 was G75.
What could be going on as I know this file runs.  I loaded it as a .cnc file like I said it opened fine but would not let me run.
Is there a way to override this or way to fix?
Any help would be appreciated.
Re: Unknow g code help
« Reply #1 on: August 21, 2012, 05:59:01 PM »
Mach doesnt support the G75 canned cycle as far as I know.
« Reply #2 on: August 21, 2012, 08:37:26 PM »
Caught my curiosity on the G75.......
According to Smid it is a peck grooving cycle for the lathe and as Hood said not listed as a supported Mach3 cycle.
So what ever machining task is being done by the G75 you will need to replace it with something else /  or code
to do the equivalent.
« Reply #3 on: August 22, 2012, 07:14:08 AM »
I am using a roouter-no lathe.  And I am cutting out parts with spiral bit and a roundover bit-so no pecking.  What would happen if I just delet that line?
Todd
« Reply #4 on: August 22, 2012, 08:04:28 AM »
What you need to do is find out what the Enroute does with the G75, as Rich said it is normally a grooving cycle in lathes.
If you simply delete it it will obviously not do whatever it is meant to do, this may make very little difference or could cause a major crash so I would advise checking the toolpath very closely if you do delete it.
« Reply #5 on: August 22, 2012, 08:37:13 AM »
Thank you Hood.
Whats the weather like in Carnoustie?
« Reply #6 on: August 22, 2012, 09:45:47 AM »
Nice and sunny, just a fine temp for me, prob 18 to 20 degrees C
