Hello Guest it is September 09, 2026, 06:37:03 AM
Author Topic: disable output  (Read 9949 times)
Offline tantan
  •  130 130
disable output
« on: August 17, 2012, 02:42:37 AM »
hi,
i want to disable/enable my spindle in mach to prevent the spindle from running from gcode or button on the machscreen. is there a way (oem code) to disable/enable the output i use to start the spindle. i allready looked in the oemlist but i could not find any, just to disable the axis.
tnx
TanTan
Re: disable output
« Reply #1 on: August 17, 2012, 02:56:40 AM »
I do this by having the enable signal  to my servo drive going via a switch on the panel, if your drive needs an enable signal then you could do it that way.
Offline tantan
  •  130 130
Re: disable output
« Reply #2 on: August 17, 2012, 03:07:40 AM »
hi, tnx hood,
that was the second option i figured out too. but it would be nice if i could block my spindle on my touch screen, thats all.
tnx tantan
Re: disable output
« Reply #3 on: August 17, 2012, 03:25:46 AM »
You could  do it that way as well with a brain or macropump that looks at a LED (Operated by a screen button) before it will enable the spndle drive.
