Hello Guest it is October 21, 2026, 08:27:37 AM
Author Topic: re:CNC Lathe program  (Read 152000 times)
Re: re:CNC Lathe program
« Reply #90 on: August 09, 2012, 12:44:11 PM »
The xml you attached was not the correct one, it had no config in it so likely it was the standard Mill one you attached.
« Reply #91 on: August 09, 2012, 01:22:14 PM »
I have gone back to a normal Lset screen and then loaded the ball tap file found the same condition made changes to the reverse arcs and diam no change in the crop circles and how can i find the backup XML for the lathe what would be its name.
Dennis
« Reply #92 on: August 09, 2012, 02:10:03 PM »
Whatever your lathe profile is called is the xml you need to attach. If for example you are using the standard lathe profile look for a file called Mach3Turn.xml and attach that (renamed for forum) If you made a custom profile then the xml will have the name of whatever you called the profile.
« Reply #93 on: August 09, 2012, 06:07:22 PM »
How about this one .
Dennis
« Reply #94 on: August 09, 2012, 06:08:42 PM »
Finlay the system took the file i had made several attempts to upload it but the system would not accept the file even changing the name.
Dennis
« Reply #95 on: August 10, 2012, 01:05:19 AM »
Atill not it Dennis.
Tell you what to do, open Mach as you normally would then go to view and load the Mill screenset then lower right you will see profile, find a file with that name and a xml extension. Before you close Mach however change back to a lathe screenset.
« Reply #96 on: August 10, 2012, 04:37:52 AM »
Modified xml from your post which will use the lathe screen. You will need to configure  it for your machine ie; tuning, pin assignments, etc.
But for now, the display will show correctly for the code posted.
« Reply #97 on: August 11, 2012, 12:34:09 PM »
Hood / Rich
Hood i look for the file Bu ti don't understand the reason to look for a mill screen set XML as i am using a modified mill screen 1024 LSET.
Rich I will load the modified XML you posted and see what gives thank you both for the help.
Dennis
« Reply #98 on: August 11, 2012, 03:10:43 PM »
Dennis
The reason I said to load the mill screen is it has the name of the profile and ths the name of the xml you need to look for. Your modified mill to turn screenset may also have that, if it does no need to load the mill one.
« Reply #99 on: August 11, 2012, 04:24:05 PM »
This is the file i found MAch loading displayed in the lower right hand corner of the screen.
Dennis
