Hello Guest it is November 23, 2026, 05:08:56 AM
Author Topic: re:CNC Lathe program  (Read 155779 times)
Re: re:CNC Lathe program
« Reply #110 on: August 14, 2012, 10:12:29 PM »
Rich, I thought Dennis said he was buying V10 as it was on special  but may be mistaken.
« Reply #111 on: August 15, 2012, 05:12:02 AM »
Dennis,
Please confirm what version your using.
« Reply #112 on: August 15, 2012, 11:47:55 AM »
I  have version 10 i have not purchased it yet as i wanted to fix the problems i was having with the example code in Mach.
Dennis
« Reply #113 on: August 15, 2012, 08:48:25 PM »
I'm sure you'll get along great with it Dennis.
« Reply #114 on: August 16, 2012, 10:58:01 AM »
Thanks guys i am trying to learn where all the buttons and switches are that make it all run.
Dennis
« Reply #115 on: August 17, 2012, 06:12:24 PM »
Guys a question regarding the use of Dolphin when designing a part should the part be in a certain quadrant like upper left hand quadrant or right hand quadrant the start of the part be up against the 00 cross heirs and so on ?like when i design for a mill part it is in the upper right hand quadrant this maybe part of my problem as well thanks in advance.
Dennis
« Reply #116 on: August 17, 2012, 06:26:22 PM »
Are you drawing the part in DolphinCAD or are you drawing in some other CAD and importing the DXF?
It shouldnt really matter where you draw as long as you pick the correct point as the origin when in DolphinCAD.
For lathe work it is normal to have the front centre of the part as the X/Z zero, That would mean all X values would be positive and all Z values negative.
I draw my parts of the upper half of the section as I have a rear turret but I would imagine you should be able to draw the lower section if you wanted, reason being when you open in CAM you get both halves of the section displayed.
« Reply #117 on: August 17, 2012, 06:46:06 PM »
Dennis,
I made a video on the three balls  from importing the dxf to machining the profile.
Send me a PM with your email address and i'll send it to you. The next one will have audio.
« Reply #118 on: August 17, 2012, 06:47:52 PM »
Should that not have a X X X rating Rich, a video of three balls? :D
« Reply #119 on: August 17, 2012, 06:54:13 PM »
Maybe when I add the audio to it. Heck I may as well include using the pp and show the mach end of it also.
BTW, I did make one with audio, but the boss was giving me some guff, made me screw it up some, and my recorded
comments were past the adult supervision warning.  >:D  ;D
The licenses work on both machines, so if one generates a request make sure that your  security is turned off.
« Last Edit: August 17, 2012, 07:00:00 PM by RICH »
