Hello
Guest
it is
October 21, 2026, 04:42:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
re:CNC Lathe program
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Down
Author
Topic: re:CNC Lathe program (Read 151954 times)
DennisF
388
Re: re:CNC Lathe program
Reply #80 on:
August 08, 2012, 02:53:38 PM »
Thanks to many buttons
DennisF
388
Reply #81 on:
August 08, 2012, 02:59:49 PM »
OK, went to config ports and pins found that reverse arcs was already checked but it was in radius so i checked the dia and loaded the balls same thing crop circles.
Dennis
Carnoustie, Scotland
Reply #82 on:
August 08, 2012, 03:09:13 PM »
Attach your xml and I will have a look.
DennisF
388
Reply #83 on:
August 08, 2012, 03:32:25 PM »
Thanks here it is.
Dennis
Reply #84 on:
August 08, 2012, 04:04:03 PM »
Dennis, that has a Mill screen loaded so I think it must be the wrong xml.
Overloaded
4,923
Reply #85 on:
August 08, 2012, 04:12:36 PM »
After changing the IK mode, are you Regenerating the toolpath/file ?
It won't show correctly until you do.
Maybe ?
Russ
Reply #86 on:
August 08, 2012, 04:25:58 PM »
See attached.....
DennisF
388
Reply #87 on:
August 08, 2012, 07:49:36 PM »
Rich
Yes it is the same screen as is used in the mill application but i modified it to use in the lathe as i did not like the lathe screen you may be right so i will change the screen to the lathe screen set up and see what happens.
Dennis
Reply #88 on:
August 09, 2012, 01:46:56 AM »
You can use the Mill screen but you MUST change the file extension to .lset. If you dont then Mach will treat it as a mill.
DennisF
388
Reply #89 on:
August 09, 2012, 12:13:04 PM »
That's exactly what i did changed it to Lset unless when i did an update the update changed it back to Mill set. Just took a look at Mach and see there are more then one XML also i looked and the screen set is named 1024 Lset so don't know whats up?
Dennis
Last Edit: August 09, 2012, 12:21:45 PM by DennisF
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Up
« previous
next »
