Hello
Guest
it is
November 10, 2026, 01:55:28 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
VB and the development of wizards
Macro won't run in MDI
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Macro won't run in MDI (Read 9111 times)
Nitromuse
53
on:
July 16, 2012, 05:08:36 PM »
Hello world,
I've written a new macro that runs just fine from the script editor but won't run from the input in MDI like all the existing other .m1s files do.
Que pasa?
Logged
ger21
6,295
Re: Macro won't run in MDI
Reply #1 on:
July 16, 2012, 06:04:41 PM »
You'll need to post the macro if you want someone to tell you why it's not working.
Logged
Nitromuse
53
Reply #2 on:
July 16, 2012, 06:55:27 PM »
here's the macro at this point;
thanks again
Logged
BR549
6,965
Reply #3 on:
July 17, 2012, 07:48:37 PM »
You need to move your macro OUT of the M1-100 range. Mach sees it as an internal macro and cannot find it.
Nice macro by the way(;-)
Logged
Nitromuse
53
Reply #4 on:
July 18, 2012, 05:36:57 AM »
Thanks for the reply. Actually I just tried renaming it to M22 instead if M2 and it ran fine from the MDI. So there must be some reserved macro numbers, does anyone know if and where this is documented. Thanks again,
Logged
Print
Pages:
1
Go Up
« previous
next »
