Hello Guest it is September 28, 2026, 09:52:19 PM
Author Topic: Mach3 Duplicating line 150 four times.  (Read 10405 times)
« on: July 11, 2012, 01:28:56 PM »
I'm running into a problem where everything past line 150 of my gCode is being cut-off(not viewable in the mach gcode cycle view) however whatever is line 150 in my g-code seems to be duplicated four times in machs gcode window however it isn't in the actual .tap file
Anyone run into this before?
Re: Mach3 Duplicating line 150 four times.
« Reply #1 on: July 11, 2012, 01:59:25 PM »
I presume this is a lathe and you are hitting the max line count of the demo. On a mill it is 500 lines before you hit the max line count of the demo.
« Reply #2 on: July 11, 2012, 02:08:26 PM »
How do I configure a license, by simply placing it into the Mach3 directory? My Mach does state that it is licensed.
« Reply #3 on: July 11, 2012, 02:11:18 PM »
Thats all you need to do so not sure why you have hit the line limit then.
If you attach your xml and your code I will see if I can replicate the problem here and hopefullt find the issue.
« Reply #4 on: July 11, 2012, 02:16:04 PM »
After doing a fresh reboot the problem fixed itself, thanks!
