Hello Guest it is October 11, 2026, 08:48:59 AM
Author Topic: Welcome To The NC Pod Development, Discussion and Support Topic  (Read 359855 times)
Re: Welcome To The NC Pod Development, Discussion and Support Topic
« Reply #40 on: October 05, 2007, 04:02:27 AM »
Hi had one for a year or so, had given up on it but with some answers found hear will give it a go again thanks
« Reply #41 on: October 07, 2007, 10:44:47 PM »
About 1 month seems to be delayed,
I took the report that I revised for one part from him.
Some his plans seem to be late, but I endure still it and wait for completion.
« Reply #42 on: December 29, 2007, 08:49:41 PM »
Hello, all which I am troubled with without working.
I found the "USB analysis" (SnoopyPro) next.
I examined "a USB driver" with this.
"The ncPUD driver" has three (Vid_16c0&Pid_056f) and cannot delete them.
The deletion of the "registry" (Vid_16c0&Pid_056f) of "Windows" is not admitted.
Did everybody try this? ???
« Last Edit: December 29, 2007, 08:54:40 PM by apollonono »
« Reply #43 on: June 06, 2008, 01:25:54 AM »
Dear sir :
 I would like to buy  NC Pod, but I am failure in download Nc pod manual in Mach website, also I can not access Nc pod website. Can anyone send the manual and quote for me. my email manager@xendoll.com
thanks
Jimmy
« Reply #44 on: June 06, 2008, 05:56:03 AM »
Hello Jimmy,
I have tested and reported this to the guys working on the server :) They are good about fixing things and should have it all fixed in about 5-6 hours ;) (They are not into work at this time of the day ;)  )
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline GWH
  •  1 1
« Reply #45 on: October 07, 2008, 08:12:14 AM »
Hello,
I am having trouble with the NC Pod timing out in MACH3 and the
only way to get it going is to restart all of the software?
I have changed my USB ports settings and it still happens? :(  ???
GWH
« Reply #46 on: December 04, 2008, 08:38:15 PM »
Hi
I get an NC code used for drive of a thing of this movie and can try it?
"www.cncteknix.com/video/motiontest.mpg"
Is there a method to send off from method and MACH3 to write in at a direct SD card sequentially to operate ncPOD?
(The movement of MACH3 is felt so that CPU movement can afford by USB-ncPOD way)
In addition, is there the cord about the exercise of four axes?
(I hope for a method to write in at a direct SD card)
The direct note cord which I made becomes the error and does not work.
(Is there clear grammar somewhere?)
« Last Edit: December 04, 2008, 08:40:33 PM by apollonono »
« Reply #47 on: May 14, 2009, 03:38:10 PM »
Hi all,
is any body has answer to my problem there : http://www.machsupport.com/forum/index.php/topic,11533.new.html#new  ?
Freddy
« Reply #48 on: December 16, 2010, 01:20:36 PM »
Can anyone give me mach pin details for ncpod?
I'm using DeskPod-NcPod-PlugIn-3.00
I need details of,
> Motor Outputs
> Input Signals
> Output Signals
thanks,
Hash
« Reply #49 on: December 16, 2010, 01:48:57 PM »
I have not my machine with me.
I could reply to you on 24th december, I could check on the PC which drive my machine.
Send me a message to make me remerber on the 24th that I have to give you this answer if you did'nt have it from another person.
Regards
Freddy
