Hello Guest it is November 13, 2026, 05:00:24 PM
Author Topic: Kasuga NC mill to CNC ?'s  (Read 211977 times)
Re: Kasuga NC mill to CNC ?'s
« Reply #140 on: June 28, 2012, 04:46:58 PM »
I just found out my encoders have a 5 week lead time and cost $255 a pop. I think I might try to figure out something cheaper/faster. Any suggestions on encoders with similar features?
« Reply #141 on: June 28, 2012, 05:15:09 PM »
How about just using the resolvers you already have. The Kflop WILL run resolvers (;-)
« Reply #142 on: June 28, 2012, 07:24:19 PM »
Not a bad idea would that limit my capabilities at all?
« Reply #143 on: June 28, 2012, 11:40:26 PM »
Pulled the bandit just now after I labeled everything.
« Reply #144 on: June 29, 2012, 12:37:36 AM »
I hooked up the signal wires to the KAnalog JP11. Z 0 & 1st ground Y 1 & 2nd ground X 2 & 3rd ground.
« Last Edit: June 29, 2012, 12:39:36 AM by K_Labs »
« Reply #145 on: July 17, 2012, 10:07:07 AM »
I ordered encoders it's a 5 week wait time... I'm a week in.
« Reply #146 on: August 16, 2012, 06:32:59 PM »
Ok so I finally got the encoders in back to the project
« Reply #147 on: August 29, 2012, 04:34:29 PM »
We just picked up an old bandit control for just under $200 that wasn't setup for a tool changer so now I can see what wires are needed for the axis an what r for the tool changer and get some progress happening.
« Reply #148 on: August 29, 2012, 09:01:20 PM »
I am new here,too.What you talk about is so interesting.
Every journey begins with the first step
« Reply #149 on: September 05, 2014, 04:00:26 PM »
Hey back again.... Took a extended break on the project because work got really busy. We managed to buy a VF2 in the mean time. Now I have some more free time and I want to pick up the project again. I just installed one of the encoders and it is working correctly. I have my signal wires on the board as well but I'm confused as to what else I need to get closer to the finish line. I have X Y and Z signal wires all coming out of a conduit along with a XE wire and I don't understand what it's for.
