Hello Guest it is October 22, 2026, 04:11:57 PM
Author Topic: Kasuga NC mill to CNC ?'s  (Read 206078 times)
Re: Kasuga NC mill to CNC ?'s
« Reply #70 on: May 30, 2012, 03:08:10 PM »
Might be worth trying but sounds from the reply that it does not work that great but you dont have anything to lose by trying :)
Regarding the bandit board that takes in the resolver signals, are there any markings or labels on the output of it, that may hold a clue as to what it actually does.
Hood.
« Reply #71 on: May 30, 2012, 03:17:52 PM »
It says axis on the front right under the JP6 cable that goes to jp1. I found that the power supply is bad on the bandit control. I was wondering if I could use a computer power supply instead.
« Reply #72 on: May 30, 2012, 03:28:04 PM »
A computer supply may be ok, just depends the voltages you need. Computer supplies have 3.3, 5 and 12v. To use a computers supply you would need to connect the power good signal wire to a gnd wire or it will not start. The Power Good wire is green on the atx connector and there is a Gnd (Black) wire right next to it, all you need is to jumper a wire between them.
« Reply #73 on: May 30, 2012, 03:33:43 PM »
Doesn't sound like it will work then my 24v is good but my 120 is dead
« Reply #74 on: May 30, 2012, 03:52:04 PM »
120v? Is that for the amplifiers?
« Reply #75 on: May 30, 2012, 04:37:20 PM »
I have my power from the wall 110 to a distribution block that goes to a power converter and makes 24V then the other wires go to a transformer or something power goes in and no power comes out of it.
« Reply #76 on: May 30, 2012, 08:35:29 PM »
Ok so Mach3 is installed Kmotion is installed. My comp recognized the board after a massive brain fart. Everything looks good now where do I go from here? Should I unhook all of the wires from the bandit control (I'll label them just in case) remove it and attempt to wire it into my KFlop/KAnalog?
« Reply #77 on: May 30, 2012, 09:40:30 PM »
YES the KFLOP will accept Resolvers.
« Reply #78 on: May 30, 2012, 11:13:29 PM »
OK well I have quit a bit of stuff now where do I start? I have been reading a bit of the manual for my NC400's. I power up the panel and I'm not getting any power to them. Do they require the bandit to be on as well?
« Reply #79 on: May 31, 2012, 05:30:58 AM »
Is there any power to the power supply for the NC400'S? If there is is there any DC output from the power supply?
