Hello Guest it is November 13, 2026, 05:00:49 PM
Author Topic: Can't map inputs to Mach with 56E  (Read 11905 times)
« on: May 10, 2012, 04:48:55 AM »
I have a problem  matching inputs to mach. With the new Plugin (201204v2) i can configure the device properly, the settings are correct shown in the configuration tool also, but i have no response from Mach (Version 42.036). Have i forgot something to configure? Unfortunately i haven't found any documentation about this plugin. Firmware is 3.0.29. Serial: 20936. I have attached a screenshot. Can anybody help me?
Helmut
In theory, there is no difference between theory and practice. In practice there is.
Offline NeoTO
  •  504 504
    • PoLabs
Re: Can't map inputs to Mach with 56E
« Reply #1 on: May 10, 2012, 04:45:52 PM »
You should use button 1900 to toggle Jog On LED. This one is 'read-only' - can only be mapped to an output.
« Reply #2 on: May 11, 2012, 02:53:50 AM »
Thank you very much, now it works perfect! Sorry for the stupid question, but yesterday i was a little bit confused  ;)
Thanks again,
Helmut
