Hello Guest it is August 26, 2026, 12:34:02 PM
Author Topic: Unwanted Step Pulses  (Read 34149 times)
  •  9,367 9,367
Re: Unwanted Step Pulses
« Reply #20 on: April 29, 2012, 11:58:01 AM »
Hi Alan,
My apologies, I did not mean to suggest that your software was not genuine I just wanted to clarify that you were not using trial or demo versions.
Tweakie
« Reply #21 on: April 29, 2012, 04:06:14 PM »
Good that you found the culprit Alan.........now I can go back to a good snooze. :D
« Reply #22 on: April 30, 2012, 08:00:34 PM »
Just found this thread.  Glad you got it solved with the new lpt port.
I didnt see anything that listed any mach 3 settings.  I am willing to bed that your original problem was the step and direction pulse width.  I have seen this before a couple times.  Mainly when running very large Gcodes with tons of Z axis moves.
Upping the step and direction pulse widths cured the problems.
Offline kcib
  •  74 74
« Reply #23 on: May 01, 2012, 09:42:32 AM »
Hi Fixittt
thanks for your response , as a matter of curiosity could you tell me what settings you use on your "Z" axis ?? velocity and acceleration as well as pulse widths ?
Many thanks
Alan
« Reply #24 on: May 01, 2012, 11:36:37 PM »
If it shows up again (now that I see it was fixed) I had a problem way back in releases that had to do with mach3 not handling a consecutive sequence of very small moves well.  The cam software I was using for 3D surfaces was set to allow scallops of nothing higher than .0001".  So there were a lot of very small moves that were stacked-up in the gcode and they were going plus/minus on all three axis. I can't remember what fixed it - maybe something to do with look ahead?  I might have had backlash enabled to correct for .002" or something and maybe turned it off?  It could have also been a release upgrade that fixed it.  You might want to try a test where you make steps or blocks that are only a few mil high and in straight lines.
Jerry
« Last Edit: May 01, 2012, 11:38:52 PM by cncjerry »
