Hello
Guest
it is
November 13, 2026, 12:39:37 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
z axis does not move
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: z axis does not move (Read 21188 times)
rodeoinamo
10
on:
April 28, 2012, 03:12:13 AM »
hi everyone,
i have a cnc router which have 3 axis. my problem is two axis work fine but, axis z sometimes move just one direction sometimes it never moves sometimes it moves both directions for a very short time. could you please help me?
Logged
Carnoustie, Scotland
Re: z axis does not move
Reply #1 on:
April 28, 2012, 04:00:49 AM »
Sounds like a wiring issue, check all wires are secure.
Logged
rodeoinamo
10
Reply #2 on:
April 28, 2012, 05:47:42 AM »
thank you hood,
i control the machine with an old laptop dell 505. when i start the z axis alone it works but when i start 3 axis simultanously only x and y move z does not. what do you think about the problem?
Logged
Reply #3 on:
April 28, 2012, 06:14:08 AM »
Using the MDI type G0 X1 Y1 Z1 Then swap the cables or pin out in configuration for the Y and Z and do the same command in the MDI.
What happens?
Logged
rodeoinamo
10
Reply #4 on:
April 28, 2012, 06:27:21 AM »
hi,
when i do g0x20y20z20 and then g0x0y0z0 x and y always work. but z sometimes moves 20 sometimes not and also sometimes moves to 0 sometimes not
Logged
rodeoinamo
10
Reply #5 on:
April 28, 2012, 06:39:39 AM »
hi,
i changed the ports but main certain problem only two axis work. 3 of them do not work together
Logged
Reply #6 on:
April 28, 2012, 06:53:10 AM »
When you changed the pinout (same as physicaly swapping wires) the Z didn't move/ was still the problem?
Logged
Reply #7 on:
April 28, 2012, 06:54:39 AM »
Are you using steppers?
Logged
rodeoinamo
10
Reply #8 on:
April 28, 2012, 08:33:34 AM »
yes i am using step motors
Logged
rodeoinamo
10
Reply #9 on:
April 28, 2012, 08:35:34 AM »
x-y-z axis sometimes x-y work z does not, sometimes x-z works y does not, sometimes y-z work z does not.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
