Mach Discussion => General Mach Discussion => Topic started by: rodeoinamo on April 28, 2012, 04:12:13 AM
Title: z axis does not move
Post by: rodeoinamo on April 28, 2012, 04:12:13 AM
hi everyone,
i have a cnc router which have 3 axis. my problem is two axis work fine but, axis z sometimes move just one direction sometimes it never moves sometimes it moves both directions for a very short time. could you please help me?
Title: Re: z axis does not move
Post by: Hood on April 28, 2012, 05:00:49 AM
Sounds like a wiring issue, check all wires are secure.
Post by: rodeoinamo on April 28, 2012, 06:47:42 AM
thank you hood,
i control the machine with an old laptop dell 505. when i start the z axis alone it works but when i start 3 axis simultanously only x and y move z does not. what do you think about the problem?
Post by: RICH on April 28, 2012, 07:14:08 AM
Using the MDI  type G0 X1 Y1 Z1 Then swap the cables or pin out in configuration for the Y and Z and do the same command in the MDI.
What happens?
Post by: rodeoinamo on April 28, 2012, 07:27:21 AM
hi,
when i do g0x20y20z20 and then g0x0y0z0 x and y always work. but z sometimes moves 20 sometimes not and also sometimes moves to 0 sometimes not
Post by: rodeoinamo on April 28, 2012, 07:39:39 AM
hi,
i changed the ports but main certain problem only two axis work. 3 of them do not work together
Post by: RICH on April 28, 2012, 07:53:10 AM
When you changed the pinout (same as physicaly swapping wires) the Z didn't move/ was still the problem?
Post by: RICH on April 28, 2012, 07:54:39 AM
Are you using steppers?
Post by: rodeoinamo on April 28, 2012, 09:33:34 AM
yes i am using step motors
Post by: rodeoinamo on April 28, 2012, 09:35:34 AM
x-y-z axis sometimes x-y work z does not, sometimes x-z works y does not, sometimes y-z work z does not.
Post by: Hood on April 28, 2012, 10:31:25 AM
Attach your xml and I will take a look at your config. Also what version of Mach are you using?
Post by: rodeoinamo on April 28, 2012, 10:42:25 AM
Mach3Version3.042.020 i use nema 23 motors, 12V 10A power supply and TB6560 driver board
Post by: Hood on April 28, 2012, 10:57:02 AM
Have sent  a PM.
