Hello Guest it is October 22, 2026, 04:31:40 PM
Author Topic: Rotary axis  (Read 9339 times)
Rotary axis
« on: April 19, 2012, 11:51:44 AM »
What are the keyboard keys for A+ and A-?  Scan codes appear to be 45,46.  Thanks.  Mike
Re: Rotary axis
« Reply #1 on: April 19, 2012, 01:02:32 PM »
I dont think there is such a thing as a standard setup for A axis but if yours is set to 45/46 then that is Insert and Delete keys on the numeric pad of my keyboard.
Re: Rotary axis
« Reply #2 on: April 19, 2012, 02:29:41 PM »
I will try that later on tonight.  Thanks you for your quick response.  4th axis(A) is sure a new learning curve.  Thanks again.  Mike
Re: Rotary axis
« Reply #3 on: April 20, 2012, 07:52:54 AM »
That worked.  Also found in the motor cable I had used blue wire on one end and green wire on other end.  Works wonders now that both phases are connected.  Guess my vision on colors need tuning.  Thanks.  Mike
