Hello
Guest
it is
October 22, 2026, 03:58:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Rotary axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Rotary axis (Read 9337 times)
p38nut
12
Rotary axis
on:
April 19, 2012, 11:51:44 AM »
What are the keyboard keys for A+ and A-? Scan codes appear to be 45,46. Thanks. Mike
Logged
Carnoustie, Scotland
Re: Rotary axis
Reply #1 on:
April 19, 2012, 01:02:32 PM »
I dont think there is such a thing as a standard setup for A axis but if yours is set to 45/46 then that is Insert and Delete keys on the numeric pad of my keyboard.
Logged
p38nut
12
Re: Rotary axis
Reply #2 on:
April 19, 2012, 02:29:41 PM »
I will try that later on tonight. Thanks you for your quick response. 4th axis(A) is sure a new learning curve. Thanks again. Mike
Logged
p38nut
12
Re: Rotary axis
Reply #3 on:
April 20, 2012, 07:52:54 AM »
That worked. Also found in the motor cable I had used blue wire on one end and green wire on other end. Works wonders now that both phases are connected. Guess my vision on colors need tuning. Thanks. Mike
Logged
Print
Pages:
1
Go Up
« previous
next »
