Hello Guest it is November 11, 2026, 11:49:11 PM
Author Topic: configuration is out by 180 degrees for some reason?  (Read 8629 times)
« on: April 13, 2012, 10:50:30 PM »
I have just finished assembling a new controller for a Routermaster 52. It all seems to work fine, but I need to rotate my image by 180 degrees. I am assuming this is possible.
When I load Gcode it displays correctly in the toolpath window. When I run it, it cuts out by 180 degrees. I suppose the simple solution would be to turn my maching around, but thats not really a solution.
Any ideas?
(please have a look at the attached images)
Thank you
Re: configuration is out by 180 degrees for some reason?
« Reply #1 on: April 14, 2012, 05:19:03 AM »
You seem to have the axis backwards, change the Dir active low settings for your axis in Motor tuning and see if that helps you.
« Reply #2 on: April 14, 2012, 12:38:29 PM »
I did what you suggested... and it WORKED PERFECT !
Thank you so much for the suggestion!
