Hello Guest it is November 23, 2026, 06:33:23 PM
Author Topic: ALT-A input to select MPG axis  (Read 8010 times)
« on: April 10, 2012, 12:55:17 PM »
Hey all,
From reading the topics my request seems very doable but I have yet to make it work.
Goal:  I would like one input (from a button) to toggle the active axis (alt-a) for my single MPG. So I would like to use a single MPG to control axis X-Y-Z.
I am using an MPG that works well. I can select the axis by using Alt-A.  I have an input that works well and I have tested it with other tasks.
What I have tried:
Go under inputs and selected my input as input #1 (it shows up under diagnostics) then the hotkey is 2145 for Alt-A.
This does not work.
Please let me know what I am doing wrong.
Re: ALT-A input to select MPG axis
« Reply #1 on: April 10, 2012, 01:07:20 PM »
Use an OEM Trigger set to 175 instead.
Russ
« Reply #2 on: April 10, 2012, 01:27:11 PM »
SWEET!
thanks it worked.
Phill
