Hello Guest it is October 01, 2026, 03:00:57 AM
Author Topic: Jogging problem Z+ and Z- always goes UP  (Read 19850 times)
« on: April 02, 2012, 03:09:06 PM »
I had to make a fresh installing of MACH3. But with jogging axis Z keys UP and DOWN make Z go up.
hotkeys for Z are 33 and 34
Any help appreciated
Rick
Re: Jogging problem Z+ and Z- always goes UP
« Reply #1 on: April 03, 2012, 01:47:43 AM »
Either you have a loose connection on the Z Dir wiring or you have the Z Dir assigned incorrectly.
« Reply #2 on: April 03, 2012, 02:58:05 PM »
Z dir is ok. I tried reinstalling Mach3 and it worked fine.
Thanks anyway.
« Reply #3 on: April 22, 2012, 06:26:13 PM »
Yes I had the same issue.  Thought I was going crazy.  Reinstallation worked
« Reply #4 on: January 06, 2013, 09:21:30 AM »
im having a similar problem
im using a bunch of cnc4pc boards with all rj45 connections
X and Y were giving similar problems and i messed around with the cables and fixed them
i got z to go  + and - at some point but it wont do it consistently
i made 3 or 4 new cables and im still having the problem
yet X and Y are still fine
hellllllppp!!!!
« Reply #5 on: January 06, 2013, 09:33:55 AM »
ill try the reinstall today and see how it goes
if it doesnt work ill post again and see if anyone has any more ideas
