Hello Guest it is November 13, 2026, 09:43:14 AM
Author Topic: mach3 loses contact  (Read 35817 times)
mach3 loses contact
« on: March 21, 2012, 01:44:04 PM »
Hi All,
I am working with Mach3 for 4 years with no major issues.
Now in jog mode (and program mode as well)  M3 is loosing contact with its steppingmotors after a few seconds/steps (random) .
After each try the steppers start for a short while/distance and then stop with no obvious reason.
Grateful for any help..
Mark
  •  9,377 9,377
Re: mach3 loses contact
« Reply #1 on: March 22, 2012, 03:13:24 AM »
Hi Mark,
Have you started using a different PC or made any other hardware changes ??
« Reply #2 on: March 22, 2012, 04:05:31 AM »
Hi Tweakie,     No i had no change in PC or any Hardware , this makes it even more difficult..........
  •  9,377 9,377
« Reply #3 on: March 22, 2012, 04:44:54 AM »
Hi Mark,
Bit of a mystery then.
Perhaps checking your voltages at the PSU and controller etc. may be the first step also checking the tightness of all the wire connections may reveal something ??
« Reply #4 on: March 22, 2012, 04:52:02 AM »
Even more complicated when i say that i use the same Pc, drivers and hardware in switchablemode for my lathe and mill.
The hardware all functions ok on my Lathe with LatheMach3
I can however i approach my mill with Mach3Lathe and then i can jog normal.
« Reply #5 on: March 22, 2012, 06:37:57 AM »
It sounds like you are in step jog mode.
If that is not the case then attach the xml for both lathe and mill.
« Reply #6 on: March 22, 2012, 07:43:17 AM »
Hi Hood,
No step mode.
Have files attached
thanks in advance
Mark
« Reply #7 on: March 22, 2012, 07:46:58 AM »
second try
« Reply #8 on: March 22, 2012, 07:47:50 AM »
third try
« Reply #9 on: March 22, 2012, 10:24:59 AM »
Seems to jog fine here with the mill xml, I will have a look later on when I get home from work and see if I can find the problem in the xml.
