Hello Guest it is November 23, 2026, 01:48:04 PM
Author Topic: mach conversion to a cincinnati sabre 750  (Read 24854 times)
« on: March 20, 2012, 03:15:31 PM »
i just got a sabre 750 and are planning on going the mach route on it. it came with the acramatic 850sx controller but i am selling it all off to pay for the iron.
1 are the brushless (i assume ac) motors on the mill now going to be costly to make step/direction run?
specs are z axis
and i assume both x and y are
this came with some bds4's that i think are the drives?
Re: mach conversion to a cincinnati sabre 750
« Reply #1 on: March 20, 2012, 03:17:56 PM »
if i cant use the motors i will just sell them off too.
i was thinking maybe the biggest keling servos would be enough. not looking for speed on this mill, just rigid,accurate and toolchanger.
it has no spindle motor and i think i might be about to get a 5-10hp on there later.
« Reply #2 on: March 20, 2012, 03:25:35 PM »
Personally I would try my hardest to keep the AC servos rather than go with hobby grade drives/motors.  You have a few options if the drives are analogue input and are ok
 Galil, DSPMC, KFlop/Kanalog or CSMIO/IP-A are 4 types of controllers that work with Mach and output analogue signals.
« Reply #3 on: March 20, 2012, 03:43:21 PM »
what kind of power supply can i use? i am out of my garage and have only good amp 220 service.
« Reply #4 on: March 20, 2012, 03:46:26 PM »
What model BDS ?
BTW they are Brushless DC drives.
« Reply #5 on: March 20, 2012, 04:13:53 PM »
looks like bds4206 23412w32
thanks on the dc!
« Reply #6 on: March 20, 2012, 04:22:07 PM »
Seems they require a 250 to 360vdc suply so your 220v should be fine once transfomed and rectified. Is there a power supply in it already?
« Reply #7 on: March 20, 2012, 04:37:16 PM »
in the drivers?
this is all i got other than a couple little transformers and what look like small breakers or relays.
http://www.ebay.com/itm/170808712652?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
« Reply #8 on: March 20, 2012, 04:57:26 PM »
Were the drives the ones that were matched to the motors?
« Reply #9 on: March 20, 2012, 05:03:17 PM »
ah ok I see that is what you are selling.
If there is no big power supply then you would need to make one as it seems the drives are DC input. As you do not need to step the voltage down you could just rectify and smooth I suppose so no transformer needed.
