Hello Guest it is November 11, 2026, 08:27:06 PM
Author Topic: Problem with mach3  (Read 11305 times)
Problem with mach3
« on: February 28, 2012, 05:40:59 PM »
Hello everyone. I'm new here and I'd like to ask you something.
I have mach3 installed on my computer. Computer is totally ok, can support mach3. When I connect cnc machine to the computer and try to start motors they are moving.......so difficult. I've tried the same motors and the same drivers on my friend computer and they work excellent. Can someone help me with this?
Re: Problem with mach3
« Reply #1 on: February 28, 2012, 05:46:21 PM »
Run the driver test and see what it looks like. Also may be your parallel port s only 3.3v and your drives require a 5v port. Another thing to try is enable Sherline mode and see if that helps.
« Reply #2 on: February 28, 2012, 05:55:53 PM »
When i run driver test, he goes crazy. Too slow/excellent/too fast... What this means?
« Reply #3 on: February 29, 2012, 01:04:51 AM »
Try the optimisation steps detailed in the document on the downloads page.
« Reply #4 on: February 29, 2012, 10:09:45 AM »
Thank you very much. Works fine now. :)
