Hello Guest it is November 01, 2026, 01:44:51 PM
Author Topic: Tool location in toolpath  (Read 20593 times)
« on: February 07, 2012, 10:08:05 PM »
When scrolling through the gcode I no longer see the location of the tool in the toolpath screen (or the part of the toolpath that represents the gcode doesn't light up) like I used too, I don't see where that can be turned on or off, do I need to reinstall Mach???
Re: Tool location in toolpath
« Reply #1 on: February 08, 2012, 02:32:24 AM »
What version of Mach are you using?
« Reply #2 on: February 08, 2012, 03:15:52 AM »
Maybe you are getting the same as I am. Please check:
http://www.machsupport.com/forum/index.php/topic,20711.10.html
« Reply #3 on: February 08, 2012, 05:14:06 PM »
After I posted this I asked myself the same question and I AM do for an update, if the problem perstis after that I'll be back.
Sorry ftom not the same problem.
« Reply #4 on: February 08, 2012, 10:11:29 PM »
New version fixed it.
« Reply #5 on: February 11, 2012, 06:20:22 PM »
That did NOT fix my issue, I do have the latest ver, I know it used to work, did I turn this off somehow??
« Reply #6 on: February 11, 2012, 06:26:31 PM »
attach your xml and some code that you have issues with please.
« Reply #7 on: February 11, 2012, 07:27:09 PM »
I tried renaming the files but I keep getting this message, what do I need to do? Sorry! There is already an attachment with the same filename as the one you tried to upload. Please rename the file and try again
« Reply #8 on: February 11, 2012, 07:35:44 PM »
 Copy it to your desktop and give it a different name, like none before.
Same with ANY file, must never match a previously sent file name.
« Reply #9 on: February 11, 2012, 07:48:37 PM »
Thanks overloaded. Hope this is what you needed Hood. Thanks
