Hello Guest it is November 13, 2026, 10:29:20 AM
Author Topic: Need help,can you help me thank you  (Read 11720 times)
« on: February 02, 2012, 01:47:59 AM »
when I turn the XYZ speed and accelerate speed up to a value,the movement will appear intermittently, I can see  the stop and movement. but I don't know how to adjust my parameters
Re: Need help,can you help me thank you
« Reply #1 on: February 02, 2012, 02:12:15 AM »
What kind of motors, drivers, machine etc have you got?
« Reply #2 on: February 02, 2012, 02:53:43 AM »
servel motors  line guide articles, ball screws
« Reply #3 on: February 02, 2012, 03:31:52 AM »
What make servos and drives?
When you say stop/start does Mach or drive fault? Is it just at the end of each move or is it during a single move?
« Reply #4 on: February 02, 2012, 05:58:16 PM »
thank you Hood. because my cutting process keep long time, so the stop/start process only keep  littile time. but it effect the cutting result
« Reply #5 on: February 03, 2012, 02:38:58 AM »
I am dorry you will need to provide more information as I cant understand what your problem is.
Tell us about your machine, what kind it is, also what hardware you are using and also try and describe your problem in a bit more detail.
