Mach Discussion => General Mach Discussion => Topic started by: wyb_506 on February 02, 2012, 02:47:59 AM
when I turn the XYZ speed and accelerate speed up to a value,the movement will appear intermittently, I can see the stop and movement. but I don't know how to adjust my parameters
What kind of motors, drivers, machine etc have you got?
servel motors line guide articles, ball screws
What make servos and drives?
When you say stop/start does Mach or drive fault? Is it just at the end of each move or is it during a single move?
thank you Hood. because my cutting process keep long time, so the stop/start process only keep littile time. but it effect the cutting result
I am dorry you will need to provide more information as I cant understand what your problem is.
Tell us about your machine, what kind it is, also what hardware you are using and also try and describe your problem in a bit more detail.
