Hello Guest it is September 05, 2026, 11:21:17 PM
Author Topic: Will any PCIe card work with Mach?  (Read 10244 times)
« on: January 17, 2012, 10:25:21 PM »
My machine only has PCIe slots in it. It looks like I am going to need a new machine. I cant seem to find any PCIe card that will work with mach.
Re: Will any PCIe card work with Mach?
« Reply #1 on: January 17, 2012, 10:59:45 PM »
Sometimes a bit tricky setting up.  Make sure the ADDRESS is setup correctly and if you make use of the Second port, make sure under your setup you tell Mach then to use port 2 pins as well..
« Reply #2 on: January 17, 2012, 11:01:49 PM »
some pictures what I am trying to explain
« Reply #3 on: January 18, 2012, 09:14:58 AM »
The strange part is that with the card im using, I can get my carriages to move, but cant get my relay to work for the router.
