Hello
Guest
it is
November 23, 2026, 08:23:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Will any PCIe card work with Mach?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Will any PCIe card work with Mach? (Read 10714 times)
Montezuma213
13
on:
January 17, 2012, 10:25:21 PM »
My machine only has PCIe slots in it. It looks like I am going to need a new machine. I cant seem to find any PCIe card that will work with mach.
Logged
woody1
14
Re: Will any PCIe card work with Mach?
Reply #1 on:
January 17, 2012, 10:59:45 PM »
Sometimes a bit tricky setting up. Make sure the ADDRESS is setup correctly and if you make use of the Second port, make sure under your setup you tell Mach then to use port 2 pins as well..
Logged
woody1
14
Reply #2 on:
January 17, 2012, 11:01:49 PM »
some pictures what I am trying to explain
Logged
Montezuma213
13
Reply #3 on:
January 18, 2012, 09:14:58 AM »
The strange part is that with the card im using, I can get my carriages to move, but cant get my relay to work for the router.
Logged
Print
Pages:
1
Go Up
« previous
next »
