Mach Discussion => General Mach Discussion => Topic started by: Montezuma213 on January 17, 2012, 11:25:21 PM
My machine only has PCIe slots in it. It looks like I am going to need a new machine. I cant seem to find any PCIe card that will work with mach.
Sometimes a bit tricky setting up. Make sure the ADDRESS is setup correctly and if you make use of the Second port, make sure under your setup you tell Mach then to use port 2 pins as well..
some pictures what I am trying to explain
The strange part is that with the card im using, I can get my carriages to move, but cant get my relay to work for the router.
