Hello Guest it is October 21, 2026, 06:28:27 AM
Author Topic: Where Can I Buy Some C4....  (Read 29941 times)
Re: Where Can I Buy Some C4....
« Reply #10 on: January 09, 2012, 09:18:11 AM »
Only difference I see regards the spindle is the frequency you have the spindle setting at, doubt that would affect anything though.  I am curious though, you have massive numbers in for  the filtering, do you really need that? Most I ever needed was 1.43 on if I recall the MPG when using the SS.
How are you coming on with the Kflop, thought you were switching to it?
Hood,
What filters are you referring to?
I am still working on the KFlop, and it's getting close.  I went ahead and started writing my own CNC Controller app for it, written in c#, which is coming along very nicely, but I just don't have a lot of time to work on it.  Most of it is now working, but I have a lot of details to clean up.  A screenshot of the main page is below, along with one of the toolpath display I intend to integrate into it.
« Reply #11 on: January 09, 2012, 09:33:14 AM »
I am talking about the filtering in SS/ESS config, you have 2000 for the first 4 and 500 on the last 3. I found whilst testing things out in the SS a long while back that 50 affected the E-Stop quite dramatically so what 500 and 2000 are doing I dont know. Maybe things have changed since I did the testing but I am not aware of it.
« Reply #12 on: January 09, 2012, 09:55:08 AM »
Hood,
Yeah, when I was writing down all the old settings I was also surprised to see that, as I don't recall ever setting any filtering - my machine is very "quiet".  I have to wonder if that snuck in as part of the dozens of new versions of Mach3 and/or SS that I've installed over the last six months, in trying to debug the problems I've had.  That's exactly why I wanted to do a clean install, and make sure I wasn't carrying over anything that might help explain the problems.  I don't see how that filtering could explain anything I'm seeing however.
« Reply #13 on: January 09, 2012, 10:05:15 AM »
Well all I can say is I have just tested setting my MPG/Encoder filtering to 2000 and if you have a MPG I dont have a clue how it works because mine wouldnt if I wound at anything more than very very.................................... very slow. If its having that effect on the MPG what its doing to the others may be similar.
« Reply #14 on: January 09, 2012, 10:18:02 AM »
Hood,
My MPG is connected to a ModIO, not the SS, so it's not affected.
« Reply #15 on: January 09, 2012, 10:35:51 AM »
Hood,
BTW - I only have home/limit switches on my Z axis, not the other three, and no spindle sensor, so those big filter values really should not have any affect on anything of consequence.
« Reply #16 on: January 09, 2012, 11:03:25 AM »
Shouldn't, well they will on the Z but who knows what else they will affect, Do you not use a probe of sorts for tool height setting? Thought you did but maybe I am thinking of someone else.
Anyway no point in have the filtering so high even though it is very unlikely to be the cause of your present issues.
« Reply #17 on: January 09, 2012, 04:36:48 PM »
Hood,
Yes, I use probing quite extensively.  I've zeroed out all those filters.  Brian helped me get the spindle going.  I have a VFD, so the spindle control is two relays and a PWM.  The PWM was the problem because I hadn't set the motor tuning for the spindle axis.  But I completely don't get the relevance, or meaning, of "Steps Per" and "Velocity" for a PWM spindle.....
The Z axis is still backwards, and both Brian and Greg are scratching their heads over that one.
Meanwhile, I finally got motivated to finish up the last few nits to get the KFlop going using their CNC controller app, and I believe it's now ready for prime time.  All seems to be working properly now on that front.  I think tomorrow I'll take it out for a maiden voyage, and see how it goes.
« Reply #18 on: January 09, 2012, 05:13:02 PM »
Never had anything otherthan servo spindles under Mach control so afraid I dont know anything about PWM.
Hope Kflop works out for you like Mach does for me :)
