Hello Guest it is November 17, 2026, 01:13:28 AM
Author Topic: dmm servos and mach3  (Read 12773 times)
« on: December 15, 2011, 08:06:07 AM »
I am trying to get the dmm 900w servos to run, everything has been set up, dmm xml files dropped into mach3.
The DRO's respond on the screen but no movement with the motors.
Port 1 is set to 0x378.
Motors are enabled.
Step Port and Direction Port at 1.
External e-switch works.
Voltage at motors 48 and cannot turn by hand when energized.
Any suggestions would be helpful.
Terry
Re: dmm servos and mach3
« Reply #1 on: December 15, 2011, 07:09:35 PM »
problem solved..........external e-switch wiring fault
« Reply #2 on: December 16, 2011, 08:22:18 PM »
I have the DMM's also....  fantastic kit!
« Reply #3 on: December 16, 2011, 08:33:39 PM »
I have them as well and am very happy.  DMM has been very helpful with any questions I have had.
« Reply #4 on: July 12, 2013, 10:25:34 AM »
Any dmm user out there? Please help. Can't get them to run
« Reply #5 on: July 12, 2013, 03:45:10 PM »
I have been using the DMM servos for a while now. Excellent product.
