Mach Discussion => General Mach Discussion => Topic started by: woodbot on December 15, 2011, 09:06:07 AM
I am trying to get the dmm 900w servos to run, everything has been set up, dmm xml files dropped into mach3.
The DRO's respond on the screen but no movement with the motors.
Port 1 is set to 0x378.
Motors are enabled.
Step Port and Direction Port at 1.
External e-switch works.
Voltage at motors 48 and cannot turn by hand when energized.
Any suggestions would be helpful.
Terry
problem solved..........external e-switch wiring fault
I have the DMM's also.... fantastic kit!
I have them as well and am very happy. DMM has been very helpful with any questions I have had.
Any dmm user out there? Please help. Can't get them to run
I have been using the DMM servos for a while now. Excellent product.
