Hello Guest it is November 13, 2026, 09:36:50 AM
Author Topic: E-stop halts movement, but Mach keeps running in the readouts.  (Read 8059 times)
Offline Jackal
  •  173 173
« on: November 27, 2011, 09:58:59 AM »
I've got everything working, but when I  hit the E-stop.
The movement stops. No charge pump running, and the E-stop lights on the B_o_B indicate E-stop.
Mach keeps running??? The readouts count along just like nothing happened.
It used to be that when I hit E-stop, Mach went into Reset Mode and you had to clear the switch, and reset Mach.
When  I was trying to get  that pendant board to work a few weeks ago, is when it changed.
What should the inputs really be for the E-stop & Reset mode?
Right now it shows to be an emulated input.
JAckal :)
Everything is bio-degradable if you run over it enough with a lawnmower.
Offline Jackal
  •  173 173
Re: E-stop halts movement, but Mach keeps running in the readouts.
« Reply #1 on: November 27, 2011, 02:50:21 PM »
Got it figured out. ;)
When  I was trying to get the pendant to work a while back, it had a interface board that came with the pendant.
It had a sample .XML file and brains & settings.
The pendant never would work with the board.
I bypassed the board and used the pendant directly with the 2nd parallel port.
After looking through the input pins , the E-stop was set for a different pin and checked as " Emulated".
Now all is good.
That is another reason  like buying all of my stuff from the same supplier.
JAckal :)
