Hello
Guest
it is
October 20, 2026, 11:40:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
A problem writing macros
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: A problem writing macros (Read 10816 times)
drbricolage
7
on:
October 20, 2011, 10:09:38 AM »
I am trying to convert my mill with Mach3 and I've run into a bit of a problem. I want to toggle an output bit to control a solenoid to lock my Z axis. I wrote two macros ( M64 and M65) as follows:
M64
ActivateSignal(output4)
and M65
DeactivateSignal(output4)
I set up the output to connect to the right pin and put these in my profile macro folder as M64.mls and M65.mls. I can't see that there is anything else to do but when I try these under MSI nothing happens. What am I doing wrong? I would be very grateful for some help.
Logged
Overloaded
4,923
Re: A problem writing macros
Reply #1 on:
October 20, 2011, 10:22:17 AM »
Try .m1s for the extension.
Also, I think you shold use macros over 100 as many below are used internally. (from memory, which is weak).
Logged
drbricolage
7
Reply #2 on:
October 20, 2011, 10:30:22 AM »
Fantastic, it works! I just couldn't see where I was going wrong. Many many thanks.
Logged
Carnoustie, Scotland
Reply #3 on:
October 20, 2011, 10:33:04 AM »
Also worth mentioning you should really be using M101 and higher for custom M codes, under 100 are meant to be reserved for Mach internally.
Logged
Print
Pages:
1
Go Up
« previous
next »
