Hello
Guest
it is
August 25, 2026, 11:59:06 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Motor tunning
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Motor tunning (Read 51782 times)
Carnoustie, Scotland
Re: Motor tunning
Reply #10 on:
October 05, 2011, 02:46:12 PM »
Ah Ok that makes more sense
If the rated RPM of the motor is stated as above then you should manage 1000rpm approx so at 2.5mm approx per rev that would work out at 2500mm/min so sounds like your tuning may be needing looked at.
DennisF
388
Re: Motor tunning
Reply #11 on:
October 05, 2011, 03:04:03 PM »
Do you think i should adjust the setting or leave them alone as they are, if you think i should adjust the setting's what is the formula to adjust them and thanks for the help.
Dennis
Re: Motor tunning
Reply #12 on:
October 06, 2011, 03:14:13 AM »
Sorry Dennis, never used Gecko servos so dont know how to tune them. What kernel are you using and what pulse width do you have set in Motor Tuning?
DennisF
388
Re: Motor tunning
Reply #13 on:
October 06, 2011, 11:32:23 AM »
I have the geckos adjusted so don't need to do anything here for kernel speed it's set to 3500 and the step pulse is 2.
Dennis
Re: Motor tunning
Reply #14 on:
October 06, 2011, 02:21:23 PM »
There must be a reason your drives are faulting, do the Geckos tell you what the fault is or does the drive just fault with no way of knowing why?
What are your steps per unit set to?
DennisF
388
Re: Motor tunning
Reply #15 on:
October 07, 2011, 02:30:51 PM »
No indicator on the geckos they just fault out don't know why. as to the steps they are calibrated for each axis but they distance is perfect no problem as i have them moving in exact amounts just the faulting issue is my only problem.
Dennis
Re: Motor tunning
Reply #16 on:
October 07, 2011, 03:34:54 PM »
Could be overcurrent, maybe reducing your accel a bit will allow faster rapids. What do you have the accel set to?
DennisF
388
Re: Motor tunning
Reply #17 on:
October 08, 2011, 11:10:28 AM »
I it set to 750 MM
Dennis
Re: Motor tunning
Reply #18 on:
October 08, 2011, 01:12:35 PM »
Might be worth reducing it a bit to see if you can increase the Velocity.
DennisF
388
Re: Motor tunning
Reply #19 on:
October 08, 2011, 02:41:38 PM »
So if i lower the accel then can increase the velocity is that how it works ? so what is your thought on how low it should be and then how high would i go on the velocity ?
Dennis
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
