Hello Guest it is October 10, 2026, 11:29:53 AM
Author Topic: Motor tunning  (Read 52691 times)
Re: Motor tunning
« Reply #30 on: October 11, 2011, 02:40:09 PM »
They look like very nice drives but wow about $200 USD +S&H to the USA a bit steep is there anything made here in the USA that would do the same?
Dennis
Re: Motor tunning
« Reply #31 on: October 11, 2011, 03:00:41 PM »
(;-) Now you have entered the CATCH22 zone. Big motors ,Big Hurry , BIG drives  BIGGER price tag.
yOu can LOOK aroound BUT you have to be REAL carefully of what you buy for the older DC motors. You may require step/dir control and most older drives for the BIG motors were analog. AND you never know how old or used the used ones can be.
The ac drives (step/Direction)I use here NEW are about $800 each. The Mazaks here are $1800 ea refurbished.
AN option may be to replace the "motors" with something MORE compatible to the lower end drives you have.  That and a little gearing MAY solve your problem and allow you a lower cost replacement IF you loose a drive along the way.
Just a thought, (;-) TP
Re: Motor tunning
« Reply #32 on: October 12, 2011, 01:32:54 AM »
You can get the Dugongs in the USA from CNC4PC I believe. There will be USA drives of similar specs I am sure but they will be Industrial marketed drives and will be more expensive. There are the Vipers and Rutex drives but lots of bad in amongst the good reports on them.
Re: Motor tunning
« Reply #33 on: October 12, 2011, 11:14:40 AM »
all good info to know i have a CNC4PC break out board in the machine now i will take a look at themwhat about larken drives ?
Dennis
Re: Motor tunning
« Reply #34 on: October 12, 2011, 01:09:03 PM »
The Larken drives were the Vipers I mentioned above. I have never used them so cant give you first hand experience but there are good and bad stories about. Suppose that can be said of most drives in this sector of the market but not heard any issues with the Dugongs yet.
Re: Motor tunning
« Reply #35 on: October 14, 2011, 10:58:06 AM »
Thanks Hood for all your help I have the machine running with out so far a drive fault out at 760 velocity and 950 on accel running the program at 350 MM per min i think that's not to bad.
Dennis
Re: Motor tunning
« Reply #36 on: October 25, 2011, 12:07:39 PM »
Would you think that the code could have anything to do with the drives faulting out i was running the machine everything was going well no problem then about @ line 7652 the drives faulted out coming out of an arc man what a pain.
Dennis
Re: Motor tunning
« Reply #37 on: October 25, 2011, 02:09:05 PM »
Unlikely to be the code.
Re: Motor tunning
« Reply #38 on: October 25, 2011, 04:27:35 PM »
well back to the money pit how much wiring change would you think i would have to do to change the drives from gecko to Dugongs
Dennis
Re: Motor tunning
« Reply #39 on: October 26, 2011, 02:05:26 AM »
Wouldnt think there would be much rewiring needed.
