Hello Guest it is November 13, 2026, 02:26:16 PM
Author Topic: mach3 ssetup  (Read 22958 times)
Re: mach3 ssetup
« Reply #10 on: September 17, 2011, 11:20:38 AM »
the parts  is  40mm x 40mm  inside hole 30mm
 after i fix the   big problem   onli is problem  with one X axis
 parts cut out dimensions 40mm Y axis  hole 30mm  and X axis 40.20mm only the  X  AXIS  is problem
Re: mach3 ssetup
« Reply #11 on: September 17, 2011, 11:26:02 AM »
Who will help me set this MACH3
Re: mach3 ssetup
« Reply #12 on: September 17, 2011, 01:44:08 PM »
Are your steps per unit correct?
Re: mach3 ssetup
« Reply #13 on: September 17, 2011, 06:19:21 PM »
i have  ste  to 400  and I lined up in a mach 3, but it's improved
Re: mach3 ssetup
« Reply #14 on: September 17, 2011, 06:31:06 PM »
i fix the  problem  thanks  hood  for  help  is work  perect  if i  cut 70mm x 40  hole  20mm  is ok perfect size  if i cut 40 x 30  hole 1  perfect   if i cut 340mm  x 140 hole  50mm  smole proble  it is 340.01  that is ok
Re: mach3 ssetup
« Reply #15 on: September 18, 2011, 02:56:00 AM »
Glad to hear it :)
