Hello
Guest
it is
November 13, 2026, 11:30:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
G73 Pullback setting
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: G73 Pullback setting (Read 10519 times)
BR549
6,965
on:
September 09, 2011, 12:32:15 PM »
Could someone verify that the G73 pullback setting is NOT being saved in the XML when you change it .
Config , port/pins, mill options, lower center of window.
Thanks (;-) TP
Logged
Carnoustie, Scotland
Re: G73 Pullback setting
Reply #1 on:
September 09, 2011, 01:11:35 PM »
I am sure I have seen mention of that before and have just confirmed it is the case.
Logged
Mats
1
Reply #2 on:
September 10, 2011, 05:44:57 PM »
It is not saved. It looks like the XML file is updated with the value 0.1 when you exit Mach3.
Logged
Print
Pages:
1
Go Up
« previous
next »
