Hello Guest it is November 12, 2026, 05:37:14 PM
Author Topic: 1997 DYNA MYTE DM4800 VMC to Mach3 Conversion  (Read 581644 times)
Re: 1997 DYNA MYTE DM4800 VMC to Mach3 Conversion
« Reply #50 on: October 14, 2011, 01:19:49 PM »
JH,
    Wow man you are simply getting WAY too good at this stuff.  You need to start a build a CNC machining center class or something....haha I would be in the front row dude!!  Nice looking machine you have there. I have seen a couple of them come and go for good prices but knew nothing about them.  Good luck on this build, I doubt you will need it. Peace
Pete
« Reply #51 on: October 14, 2011, 06:47:12 PM »
JH,
Pete
Thanks Pete !  It's a beast, got the Y axis moving today ...  It's been 2 steps forward and 1 step back on this project.
ATC Carousel Update
« Reply #52 on: October 17, 2011, 11:39:22 AM »
The ATC Carousel circuit was constructed and installed into the machine.  Wrote some test macros to verify that Mach3 can rotate the carousel in both directions using the DIR and ON/OFF control lines.
The INDEX switch has been added and a new flag was tack welded to the rotating motor plate.  I made the flag long enough to indicate that the entire range is a valid INDEX position while allowing the motor to decelerate and stop from both directions.  The HOME switch has been mounted but the HOME flag needs to be constructed and attached.  Once the sensors are installed, the BP412 Carousel Code will be modified to support 24 positions and tested.
JH
« Reply #53 on: October 17, 2011, 07:43:29 PM »
JH are you using Modbus and a VB script to enact tool changes? Or?
Thanks!
« Reply #54 on: October 18, 2011, 01:20:50 PM »
Yes, VB script for the logic and error handling.  I plan to use both PP I/O and some ModBus I/O for this DM4800 project.  Any I/O will work as long as you can write a macro to access the hardware.
I have attached my M6Start Macro that I used on a BridgePort 412.  I plan to use this and modify it for the DM4800.
If it works for you, then I'll take credit, if it doesn't work, I didn't write it :)
JH
« Reply #55 on: October 18, 2011, 06:27:08 PM »
Many Thanks! I have so much to learn. It is overwhelming. Having a hard time even picking a place to start on my machine.
« Reply #56 on: October 28, 2011, 07:32:43 PM »
HELP
i just purchused a dm4500 1995  im having trouble getting this machine to do anything in mdi memory.I can zero return it i think but thats it ive talk to the original owner it was running about 4 months ago replace the battery and restarted the process really need help im in ma.   NEED HELP
WAYNE
508 6413239
« Reply #57 on: October 28, 2011, 08:13:12 PM »
HELP
WAYNE
508 6413239
You try the zone for help.
http://www.cnczone.com/forums/dyna_mechtronics/
JH
« Reply #58 on: October 28, 2011, 08:43:59 PM »
yes i have no luck yet.I used to fanuc and yasnac controls (robo drills matsuura)this a little different than what im used to
Offline cnc-it
  •  153 153
« Reply #59 on: October 30, 2011, 12:22:18 PM »
Hi Wayne can you check if it's stuck in manual mode. Might be a bad start switch or auto/manual switch. Or a feed hold switch stuck on?
Faulty contacts on switches are a good place to start...if it's been sat idle for some months the contacts can corrode with the damp..or the switch contacts simply wear out on older machines. You can usually check them in the diagnostics screen.
John
