Hello Guest it is November 23, 2026, 05:19:56 AM
Author Topic: Question regarding mach3 function  (Read 8498 times)
« on: September 02, 2011, 10:15:24 AM »
Hi guys,
I was wondering if in one of the latest version of Mach3 lathe, or using a created program, is there a function that stops the machine with an error IN CASE the drives are not giving the correct pulses to the computer.
Re: Question regarding mach3 function
« Reply #1 on: September 02, 2011, 10:43:38 AM »
Drives take the pulses not give.
However if your drives support fault output signals then you can put them in to Mach to halt all motion if one axis faults.
