Hello Guest it is October 23, 2026, 04:26:34 AM
Author Topic: Shuttle question  (Read 13829 times)
Shuttle question
« on: December 10, 2006, 01:46:25 PM »
Is there a way to change the jog increment from .1 to .01 to .001?
Couldn't find the key.
Thanks.
Dan.
ynneb
Re: Shuttle question
« Reply #1 on: December 10, 2006, 03:40:01 PM »
Press the TAB key on your keyboard. The jog control should appear. From memory there is a increment setting in there.
« Reply #2 on: December 10, 2006, 08:59:46 PM »
What I am wondering is if you can change the jog step on the shuttle.
« Reply #3 on: December 11, 2006, 07:41:30 AM »
Change the jog inc on the Tab screen and that will change the inc move for the shuttle
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: December 11, 2006, 05:51:43 PM »
Thanks for the replys.
The only increment my shuttle will change by is .1 in a positive or negative direction.  I tried changing the jog amount in the MPG window to .001 but when I go back to the shuttle it increments by .1 for every button push.
Am I doing something wrong?
Thanks for all the support.
Dan.
« Reply #5 on: December 11, 2006, 07:49:34 PM »
Still does not work even after I fixed the other issues.
Offline faby
  •  74 74
« Reply #6 on: December 12, 2006, 04:44:13 AM »
If I understand what you mean, there's a way to assign it in  the plugin configuration screen.
Faby
