Hello Guest it is November 13, 2026, 09:39:31 AM
Author Topic: Uploads from Lazycam  (Read 9212 times)
« on: July 10, 2011, 07:16:47 PM »
Uploading from Lazycam to MACH3 has gone haywire. Any DFX files I try to convert to G Codes using Lazycam are not fully loading into MACH3. In fact they only load to 250N and then stop, in all cases. Even older files that were already converted to G Codes only load to 250N. Any program less than 250N load fine. I purchased MACH3 from Artsoft and it is a licensed version. Why would this all of a sudden begin to happen? It worked last Thursday, July 7, but has not worked since. I completely deleted the MACH3 and Lazycam programs and reloaded. Other than IE there are no other programs loaded on this computer.  Any ideas?
Re: Uploads from Lazycam
« Reply #1 on: July 10, 2011, 07:38:31 PM »
Sounds like you deleted the license file.
If you go to Help>About, you should see you're name. If not, the license file is missing. You'll need to copy it back into the Mach3 folder.
« Reply #2 on: July 11, 2011, 06:27:55 AM »
My name is there, and the MACH3 opens with "Licensed to Peter..................."
