Mach Discussion => General Mach Discussion => Topic started by: Peter J on July 10, 2011, 08:16:47 PM
Uploading from Lazycam to MACH3 has gone haywire. Any DFX files I try to convert to G Codes using Lazycam are not fully loading into MACH3. In fact they only load to 250N and then stop, in all cases. Even older files that were already converted to G Codes only load to 250N. Any program less than 250N load fine. I purchased MACH3 from Artsoft and it is a licensed version. Why would this all of a sudden begin to happen? It worked last Thursday, July 7, but has not worked since. I completely deleted the MACH3 and Lazycam programs and reloaded. Other than IE there are no other programs loaded on this computer. Any ideas?
Sounds like you deleted the license file.
If you go to Help>About, you should see you're name. If not, the license file is missing. You'll need to copy it back into the Mach3 folder.
My name is there, and the MACH3 opens with "Licensed to Peter..................."
