Hello Guest it is November 07, 2026, 04:04:25 AM
Author Topic: New User - bought used machine- was running.....  (Read 9939 times)
« on: April 19, 2011, 06:54:50 PM »
I bought a used machine ( Townlabs TL518) using Mach3.....running under a build of R1.  Brought it home, loaded R3 but now it doesnt operate.
Issues....
I tested my LPT port, but it finishes ( i think) and the screen disappears, saying Mach1 test complete....so did I pass???
Jogging the machine......all axis are very jerky......
Ok....where do I start now to rectify this glitch?
Motherboard of the PC is an Asus P4B.....LPT is running ECP....
thanks in Advance......
Sam
  •  9,375 9,375
Re: New User - bought used machine- was running.....
« Reply #1 on: April 20, 2011, 01:20:33 AM »
Sam,
When you say axis are jerky, is that just when starting and stopping (reduce acceleration in motor tuning) or does it just not run smoothly ?
« Reply #2 on: April 20, 2011, 06:05:19 AM »
Tweakie.....
It is all the time.....also, the delay from when you stop pushing the button to when the axis actually STOPS moving is like a second or more......seems very wierd.
  •  9,375 9,375
« Reply #3 on: April 20, 2011, 06:34:33 AM »
I think you need to go into motor tuning and set up your motors (Config / Motor Tuning). Increasing the acceleration will reduce the start and stop delay. Don't forget to save your settings / changes for each axis before moving on to the next.
