Hello
Guest
it is
October 02, 2026, 09:48:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
FAQs
Jog ok, g code steppers just screech
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Jog ok, g code steppers just screech (Read 8656 times)
DMF
17
on:
March 28, 2011, 08:48:43 AM »
I set the steps per to 2000, feed rate at 12. Jog either with mouse or keyboard is ok. When I try MDI and g code the x and/or steppers just screech. It sounds like their trying to run too fast. What did I miss?
Tweakie.CNC
9,374
Super Kitty
Re: Jog ok, g code steppers just screech
Reply #1 on:
March 28, 2011, 08:55:59 AM »
Hi and welcome to the forum.
Go back to motor tuning and reduce you velocity settings by about 20% to 30% below the point at which they stall and screech then save the setting before proceeding to the next axis etc.
Last Edit: March 28, 2011, 08:58:17 AM by Tweakie.CNC
Overloaded
4,923
Reply #2 on:
March 28, 2011, 09:05:40 AM »
... also, when jogging to set the tuning, set to 100% (pic) to jog full rapid speed, or hold down the SHIFT key while jogging.
Russ
DMF
17
Reply #3 on:
March 28, 2011, 01:49:09 PM »
I was jogging at 100%, reducing the velocity fixed the issue. Thank you.
Print
Pages:
1
Go Up
« previous
next »
